  3. Routing nets of same length
  • Subscribers 163
  • Views 13990
tltoth
tltoth over 16 years ago
How can we make the PCB Router to route nets of same length? (e.g. buses)
  • oldmouldy
    oldmouldy over 16 years ago
    You will need the appropriate product level to configure the constraints in PCB Editor and the appropriate product level for PCB Router - which would be Router Performance, or Performance Option for PCB Editor - then PCB Router will follow the length constarints as far as it is able within the confines of the design.
  • tltoth
    Is the "Allegro PCB Performance Option L" adequate for this?
    If yes, which property refers to the length of nets in Constraint manager?
  • redwire
    redwire over 16 years ago
     Perf L is good.  Look under Electical Constraints and learn about Relative Propagation Delays and Min/Max routing.  Both will get you there but there is a distinct difference.
    Do some searches on here where I posted an archive for a guy looking how to do this.  It has a schematic and PCB for experimentation with these properties.
  • tltoth
    Thank you redwire.
    I give it a try.
  • tltoth
    Thanks redwire.
    I've found those files, but what is the difference between matbus.brd and matbus16.brd?
    Both have RELATIVE_PPROPAGATION_DELAY_TOL = 200 mils and they are routed differently.
    tltoth
