  3. Creating Stubs for Terminating Resistors
  • Views 15494
EllieRye
EllieRye over 17 years ago
I am designing a PCB for a BGA. For the BGA inputs, I'd like to use terminating resistors so that physically they are as below:
Input------------->BGAPin------>resistor
However, the auto routing tools (understandably) want to route it as:
 Input------------->Resistor----> BGA Pin
Is there a way to specify a t-connection on the BGA pin, or some way to enforce the way nets are interpreted physically?
Megan
  • redwire
    redwire over 17 years ago
     Look up net scheduling.  Or better yet, pin escape it the way you want and move on.
  • hadeti
    hadeti over 17 years ago
     Creating stubs can lead to Signal Integrity Issue. I will suggest you pick up a signal integrity book. For example"Signal Integrity for PCB Designers" by Vikas Shukla or "Signal Integrity Simplified" by Eric Bogatin.
  • dschaefer
    dschaefer over 17 years ago
     Here's a sample of net scheduling within a Specctra .do file (Allegro Router):
    define (net D5
    (fromto U6-5 RN1-6 )
    (fromto RN1-6 U7-5)
    Lots of other controls you can add ..
    Hth,
    Dave
  • EllieRye
    Thanks Dave, that was just what I needed.
    Megan
