  3. Allegro 15.2 - Importing Logic - 'name too long' error
  • Subscribers 167
  • Views 5764
archive over 16 years ago
Have taken on a job from a new customer who passed on all design files including ConceptHDL schematic including lib archive etc. and Allegro PCB file.
I can open, view and edit the schematic with no problems - all symbols present. I can package the design (Export physical).
The problems arise when I try to import the logic into Allegro. I just get a pile of errors reported.
 I always thought that long names were truncated automatically - or was that something else altogether? Please can anyone assist?
 Here is a snippet from the netrev.lst log file
Using Design Entry HDL & PCB Editor 15.2 running on Vista Business.
Rob
#1   ERROR(302) Device library error detected.
Problems with the name of device 'STANDARD_FERRITE_SMT-1500R[100MHZ],0.40,0.5,MULTIA': 'name too long'.
Device 'STANDARD_FERRITE_SMT-1500R[100M' has library errors. Unable to transfer to Allegro.
#2   ERROR(302) Device library error detected.
Problems with the name of device 'SINGLERESISTOR_0402-220K,1%,63MW': 'name too long'.
Device 'SINGLERESISTOR_0402-220K,1%,63M' has library errors. Unable to transfer to Allegro.
#3   ERROR(302) Device library error detected.
Problems with the name of device 'POLAR_CAPACITOR_RADIAL-ELECT,100UF,6.3MMX7MM,10V,A': 'name too long'.
Device 'POLAR_CAPACITOR_RADIAL-ELECT,10' has library errors. Unable to transfer to Allegro.
#4   ERROR(302) Device library error detected.
Problems with the name of device 'MOSFET_PCHANNEL_SOT23-1R3,0.18A,60V,NDS0605': 'name too long'.
  • malcs
    malcs over 16 years ago
    Rob,
     Create a system variable ALLEGRO_LONG_PACKAGE_NAME and give it the value TRUE.
     Cheers,
    M.
    That cracked it!!
     What can I say? Malcs, you are a star.
     Thanks a lot.
     Rob
  • Pieman
    Pieman over 14 years ago
     I have just moved to Windows 7 and am having that same issue.  At first it would not even try to create a netlist, then I saw a thread that said I had to launch Orcad Design Entry as an Administrator (RM on Orcad Design Entry then choose - Run as Administrator).
     When I try to create a netlist with the configuration Device/Net/Pin/Name Char Limit set to anything above 31 I get the "Name too long" error.  I have tried to set a system variable as follows without success:
    set ALLEGRO_LONG_PACKAGE_NAME = TRUE
    set ALLEGRO_LONG_PACKAGE_NAME TRUE
    I must not have the correct syntax.
    Please help if you can.
    My email is mlaw@cardaccess-inc.com
    Thank you.
    Marvin Law
  • fxffxf
    fxffxf over 14 years ago
     The env variable, ALLEGRO_LONG_PACKAGE_NAME, onlyapplies to 15.x releases. Starting with 16.0 the variable, ALLEGRO_LONG_NAME_SIZE, is used to set the design name length used when for new designs (including symbols and padstacks).
         set  ALLEGRO_LONG_NAME_SIZE = 255
    Depending on your manufacturing processes, you may wish to use a smaller value then 255.
    For existing designs, you can changed the length by picking Menu Setup-> Design Parameters (or prmed cmd), selecting the Design tab and changing the "Long Name Size" value.
  • Sachin Tiwari
    Sachin Tiwari over 14 years ago
      Rob,
     I am getting a error "Unable to find pinname in adfncpin"
    I found that this might be because of the number of characters in pin name. Let me know how i can change the character length, whose default value seems to be 31 (not sure).
    I am guessing that by chaging this default value to 255 can make it work.
     Similar to what you had done before. Creating a system variable ALLEGRO_LONG_PIN_NAME and give it the value TRUE
     I am not sure how to do it. Kindly let me know the steps to create this variable. Meanwhile I am using cadence 15.7 version.
     Regards
    Sachin
