  3. Valout script for windows or UNIX
  • Replies 12
  • Subscribers 168
  • Views 20234
CADcaveman
CADcaveman over 16 years ago
Can any one tell me where I can getan up to date script that produce the following files for manufacturing?
 ( brd.txt, pad.txt, sym.txt, and rte.txt)
Thanks in advance for any help
  • CADcaveman
    It happened for all parts that had fiducials no errors in extract log, records were actually there it was the vendors problem some how the fiducial screwed up the input to the machine
    Mike
  • dschaefer
    dschaefer over 16 years ago
     May be the same problem I ran into ...
    Allegro outputs records separated by type Package / Mechanical / etc., many 3rd party input translators don't handle this (I found this to be a problem with both Circuitcam and Fabmaster, not sure of others).
    What I did to resolve was to add all required items as Package parts (driven in netlist from schematic) - this resolved my issues with the input translators I mentioned.
  • Cadpro2K
    Cadpro2K over 16 years ago
    Don't know if this will help (or hinder), but I've never had to create a CADCAM output. I've always used this CircuitCAM routine for outputting manufacturing data to my assembly house.
    CircuitCAM.zip
  • Rajiv Vig
    Rajiv Vig over 16 years ago
    Dear All I have the same requirement " to generate the ASCII files that our PCB manufacturer needs". I tried the CircuitCAM. Zip file as per the instructions given. but I was unable to use it. It shows an errror " Empty variable definition". Parse error in file C:\projects\.....................line 11. Please let me know how to execute it. Thanks in advance Rajiv Vig
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    I've previously incorporated this into a skill routine. I've only tested this using the Windows version of Allegro 16.2 - the skill routine creates a file called "ccam.cad" for use in CircuitCAM.
    Please feel free to change the program to suit your needs.
    Place the skill file in your skill directory and load it.
    To run it, type ns_aegis and it will create the file and show it.
    Best regards
    Ole
    ns_aegis.il
