  3. Deleting only part of a Cline
  • Views 14926
EllieRye
EllieRye over 16 years ago
I am using PCBEditor 15.7. If I have a long, complicated net and I want to only delete part of it, is there a way? It seems silly to route an entire net, make a mistake at the very end, then have to delete the whole thing, so I must be missing something...
Megan
  • EllieRye
     Ah, I realized I can just right-click->Cut instead.
    Megan
  • pakistan
    pakistan over 16 years ago
    I think you have to choose edit>delete and then go to finds tab and click "All Off" then check "Cline Segment" and then click the cline portion that you want to delete.
    Regards
    Tanveer
  • godo baja
    godo baja over 16 years ago
    Yes, there are two ways to delete the portion of the net. Either you can use the Edit>Delete or Delete icon. Then on the right side pallette click button "All Off" and select only the "Cline Segs".
    And the second way is to click Edit>Delete or Delete Icon, then click right mouse button and there is a pop-up appear and click "Cut". Then select the portion of the net you want to delete.
    If there is an existing Skill Program that can delete it more quickly, So that is a better way to do. :)
