  3. how to do igs & step export in allegro
  • Replies 11
  • Subscribers 167
  • Views 9382
girish
girish over 17 years ago
Hi Good Day! ,Any know how to convert 3D data (IDF export ) from allegro to .igs or .step format ,or there any direct export is possible ? Regards,Girish Kumar
  • steve
    steve over 17 years ago
    Kumar
    The only way I know is to import the idf file into a 3D tool (pro-e or solidworks) then generate the step or iges file from that.
    Steve
  • girish
    Thanks Steve for your input .
    Oh its needs one more software! Could you  pls tell me which format I need to export the IDF file so thet I can gnereate other format (.EMN or .BDF becoz in IDF export menu there are 3 option PTC ,SDRC IDF)
    Girish Kumar
  • steve
    Girish
    PTC will generate EMN and EMP, to get the BDF file you need to use the IDF type.
    Cheers
    Steve
  • ahkuih
    ahkuih over 17 years ago
    Hi Steve,
          I having difficulty to find any application tools to open *.emp and *.emp file generated from PTC option. Pls advise.
  • girish
    Its simple. You can open with note pad (emn & emp is a text file ) Regards,Girish Kumar
