  3. Artwork control form
  • Subscribers 166
  • Views 13646
Carvey
Carvey over 16 years ago
Setting up above for artwork generation and recieve the following warning when I open up the above.
Database resolution exceeds the artwork output resolution.Some round off of coordinates may occur unless the number of decimal places for artwork is increased. Change format decimal places.
Design parameters;  units mills, accuracy 2
Artwork control form;  output inches, format decimal places 3
Change to what?
  • jch teyssier
    jch teyssier over 16 years ago
     mills = inch with accuracy 4
    In your case, you have to set output inch, accuracy 6 (4+2) (or 7 if use rs274x to be able to draw entities)
  • Carvey
    Still not sure what I’m doing yet.
    In the shape parameters I had Gerber 4x00 selected and we are going to use RS274X.
    Once I changed that I had to update plane data.
    Now when I go back to the artwork control form and select RS274X I still get the same message as before.
    I have reviewed the help files on Raster format but still don’t know what numbers to put into place.
    Right now the numbers are integer 5, decimal places 4.
    It is still not right.
    I tried putting in a 7 as you suggested but it says the range is only (0-5).
  • jch teyssier
     Oops, i realize that "inch" is not the real term in artwork params: it is not inches but mills (why cadence writes inch here???)
    So 5 decimal place is enough.
    Integer 5: your design can be 9 inch long (or 9000 mills!)
    So 5 for integer and 5 for decimal should do the job.
    If your design is more than 9 inch long, increment accordingly integer.
    And yes shape parameters should match with gerber parameters.
  • Carvey
    I think I’m on the right track now.
    Thank you.
    carvey
