  3. Import Text File in to the Schematics
  • Views 15905
Muthu
Muthu over 17 years ago
 I am trying to import BOM.txt file in to the schematics.But the option is given only for image insert.
 Is it possible to import the text file in to the schematics? If possible then how?
  • Chalford
    Chalford over 17 years ago
    In Allegro Design Entry HDL you use Text/File from the menus. Then select a text file and place on the schematic canvas.Usually requires some changes to the text size / line spacing to get what you wanted.
    /C
