  3. Adding via in Allegro 16.2
  • Subscribers 167
  • Views 24562
seng1
seng1 over 16 years ago
I searched and ended up nowhere. can someone instruct me to add via in allgero 16.2
  • pakistan
    pakistan over 16 years ago
    You can add via during routing by double click on the point where you want to add via.
    Regards
    Tanveer
  • seng1
    thanks but I need to know where i can add more via to the list so i can select the one i want.  I used allegro 15.2 before and i can't seem to find where to find the list where i can add more via.
  • pakistan
    Go to Setup>Constraints>Physical and in the Via column click on via and change it
    Regards
    Tanveer
  • seng1
    That’s the problem I don’t have a “via” column? Don’t know why.
  • Prasanna
    Prasanna over 16 years ago
    Hi,,
     There could be the possibility of hidden columns. Place your cursor on the column line after the neck column and double click. If the via column was hidden then it would expand and you can enter dif. vias.
    hope this helps,.....
    Prasanna Hegde
