  3. ODB++ output
  • Views 16642
ODB++ output
MAAC
MAAC over 17 years ago
Has anyone encountered the problem while generating the valor output. I am getting the following error when i try to Begin translation
eif_cadence-583003-Error translating input record.
Also after choosing ODB++ from the PCB Editor it prompts me to extract net impedance average. Is it required? wht is the effect on the manufacturing data.
Thnx
  • steve
    steve over 17 years ago
    Hello
    Check your artwork settings (Manufacture - Artwork) and make sure you can generate artworks the old fashioned way. Normal settings are RS274X. Once these are all set you should be able to generate your ODB++ file. In regard to net impedance average will export the net impedance average. Valor has the ability to check some of this stuff. If you don't use it then don't set it.
    Steve
  • MAAC
    Thnx steve...its working fine
