  3. Crossprobing - selecting whole schematic page.
  • Replies 8
  • Subscribers 166
  • Views 5344
JPeter
JPeter over 16 years ago
Hi, all.
I am a Cadence newbie, using 15.7
I can crossprobe and select a part in the schematic, and have it highlighted in PCB Editor.
But I want to select a WHOLE schematic page, then go into PCB editor and have them stuck to my mouse, or ready to be moved.
I don't want to have to CTRL click each and every part.
Thanks.
  • randydawson
    randydawson over 16 years ago
     JPeter,
    You can do something very similar to what you want, if you create your design using hierarchical blocks.  Imbedd your schematic into a hierarchical block, then when you select the block, all the parts in the schematic will highlight and move as a group.
    Question for you, i can seem to crossprobe in reverse as easy, select a part in layout and zoom to the schematic page.  the only whay I can make this work is select a function in the pcb like chage color, then select the symbol and then the schematic will zoom to the part.
    How do you do this with out selecting a function?  Even show element, select symbol will not zoom to the part in schematic.
    I would like to see some dicussion, tech notes or point me to the right places in the manuals that cover crossprobing.
    Randy
  • CubbyBear
    CubbyBear over 16 years ago
    Crossprobing never seems to work the same way twice. I found that if highlight is selected in layout, Cadence will zoom in on the schematic part.
  • Bennigin
    Bennigin over 16 years ago
    Crossprobing works with the highlight/dehighlight tool. If you select a part in the schematic it will highlight the part in Allegro (it only works if there is no active command). If you highlight a part in Allegro it selects the part in the schematic. I haven't found a way to have it stick to the mouse as in the move function. It would be nice if it did work that way.
  • CubbyBear
    In 16.2 the part will snap to the cursor. Select the Place Manual icon, then select the part in the schematic. The part will snap to the cursor. If the part is unplaced, the icon Place Manual with the list shown will snap the part to the cursor.
  • EvanShultz
    EvanShultz over 16 years ago
    Steve is correct that if the Placement window is open (Place > Manually) you can click on schematic parts to pull them from the place queue and attach the part to the cursor in PCB Editor 16.0+. Unfortunately, the OP said he is using 15.7 and I don't believe you could do that before 16.0 (been too long and don't have it installed anymore to check).
    In these cases, I have used the ROOM property. By attaching a "ROOM = DSP" or "ROOM = DDR3"(without quotes) property to schematic parts, those parts can be placed all at once on the PCB. By using a ROOM property you can subdivide hierarchical blocks even further, should you wish. With 16.2 placing a property on multiple parts is much easier, again unfortuantely for the OP.
    Crossprobing is hopelessly broken as far as I can tell. I have submitted many SRs hoping to get what I believe is common-sense crossprobing (backed up by the crossprobing of other ECAD programs I've used). Hopefully Cadence will address the myriad of crossprobe shortcomings in the future.
