  3. Creating Rat Ts pin pairs for Total Etch Length constra...
  • Replies 12
  • Subscribers 166
  • Views 19325
Creating Rat Ts pin pairs for Total Etch Length constraint
mvonahnen
mvonahnen over 16 years ago
 It is possible to create pin pairs for the Total Etch Length constraint?  I have a DDR configuration where I need to match the length of the address signals which are branched to multiple chips (4) to the length of the data lines that are a point to point signals.  It is straight forward how the match the signals within the groups (address, cmd, and data) but it is not clear how to match the groups to each other, which is a requirement.
  • redwire
    redwire over 16 years ago
    Cadence covers this example in their Constraint Manager User's Guide.  Look at "Match Groups" in the index. Scroll on down and you'll see how to get busses to match with individual match properties set within the groups.  DDR is explicitly covered.
  • mvonahnen
     Thanks, I have looked over this.  I take it from your response that there is no way to create pin pairs for Total Etch Length?
  • redwire
     Lock in a target on total etch with a single net pin pair and the relative will follow.
  • mvonahnen
    I guess you are missing the point.  I need to match a tree structure with a point to point.  It is straight forward to match pin pairs in relative distance, but how do you match a combination of 3 pin pairs to a single line?  My intent was to specify each of the legs independently and the sum of their distance would be the specification for the data line.
     Other than a two stage routing (once using relative for the tree structure and a second for the point to point lines), I don't see how this can be specified.
  • Khurana
    Khurana over 16 years ago
    Create another match group which is inclusive of 3 pin pairs and single line (single line will also be a "pin pair" since you said it's point to point).
