  3. Pads File to Board File
  • Views 15384
archive over 16 years ago
Hi All,
I have couple of PADS file and I need to perform SI analysis on it. Since I have been using PCB editor and PCB SI tools, I was wondering if I can import PADS file directly into PCB Editor and PCB SI tool without loosing any information.
Gaurav
  • Chalford
    Chalford over 16 years ago
    Hi Gaurav,
    I  often run sims of PADs designs in Allegro PCB SI. The basic flow is as follows;
    1/ Save the PADs design out as an ASCII file - you may have to revert to an older PADs version, such as v5.0 (see header below)
    !PADS-POWERPCB-V5.0-BASIC-250L! DESIGN DATABASE ASCII FILE 1.
    *PCB*        GENERAL PARAMETERS OF THE PCB DESIGN
    2/ Run import PADs utility from Allegro PCB editor (not PCB SI)
    3/ Set up the mapping file to map the layers in the PADs design to the layers in the Allegro design.
    4/ Import PADs
    5/ Check pads_in.log file:
    Closing database.
    Translation complete.
    Finished reading input file with no errors.
    Typical problems that can create a lot of work are that values are missing, so if you have lots of different R and C values it can take a long time to set up the ESPICE models.
    Good luck, come back if you have any problems!
    Chris
  • Chalford
    Hi Gaurav,
    Expanding on the above, you can run the pads_in tool from within PCB editor OR PCB SI.
    Also, the mapping I referred to is done by an .ini file. The default one is in the tools/pcb/bin directoryand is set up for mapping a 6-layer board. Edit this file to set the layers you require...
    [Options]
    CreateSolderLayers=0
    SolderOversize=0
    [Line Map]
    0=BOARD GEOMETRY|ALL
    1=ETCH|TOP
    2=ETCH|INTERNAL1
    3=ETCH|INTERNAL2
    4=ETCH|INTERNAL3
    5=ETCH|INTERNAL4
    6=ETCH|BOTTOM
    7=UNUSED|-
    8=UNUSED|-
