  3. delete by box in 16.2?
  • Views 15087
993pilot
993pilot over 16 years ago
I've just started using 16.2, and was wondering if you can put a box around traces and have it delete just the part inside the box.
If not, I can't believe Cadence still has not added this. Is the only option still to use the skill routine "cline_cut"?
Gary
  • 993pilot
    Hey Steve,
    Yes, this is the way I ended up doing it. It is very time consuming when you have to do it to an entire memory interface!
    I have since received a copy of the "clinecut" skill file for the next time I need to do this, thanks Sunil!
    Gary
