  3. delete by box in 16.2?
  • Subscribers 163
  • Views 16909
993pilot
993pilot over 17 years ago
I've just started using 16.2, and was wondering if you can put a box around traces and have it delete just the part inside the box.
If not, I can't believe Cadence still has not added this. Is the only option still to use the skill routine "cline_cut"?
Gary
  • EvanShultz
    EvanShultz over 17 years ago
     Hi pilot,
     Here's what I do, that should work for you. Enter Delete mode, and then set the Find filter to Clines, Cline segs, or whatever you want. Then you can draw a box around just the objects you want to delete and those elements will highlight. Click again and the highlighted elements will be deleted.
     I believe that accomplishes what you want. If it doesn't, let us know and we'll try to figure out a solution for you.
     FYI, I think this behavior has been the same since I started using Allegro, which is only since 15.5.1.
  • 993pilot
    Evan,
    No, that's not exactly what I want to do. I want to "chop out" a section of a horizontal trace ("cline seg").
    Imagine a large bus running horizontally:
    _________________________________
    I want to end up with a piece deleted in the middle of each:
    _____________    __________________
    Way back, a CAD system called Cadnetix could do this easily. Just get in delete, draw a box, and the sections of each trace within the box would be deleted.
    Thanks for the reply!
    Gary
  • EvanShultz
     Hi Gary,
     Yes, I believe clinecut.il is the only way to accomplish that.
  • 993pilot
    Hi Evan,
    That's what I thought. Maybe someday Cadence will include that feature.
    Gary
  • steve
    steve over 17 years ago
    You can do this inside PCB Editor but on an individual cline. Invoke the Delete command (Edit - Delete) then RMB the cline you want to cut and you will see a command "cut". Select your first pick then second pick the RMB Done. Track is removed.
    Steve
