  3. How to change default Text block sizes
  • Views 13944
pakistan
pakistan over 16 years ago
I want to set text block sizes that whenever I start a new board I dont have to set text blocks even dont need to load any parameter file and text blocks automatically set to my custome sizes. Is there any way to define any where.
Regards
Tanveer
  • steve
    steve over 16 years ago
    Tanveer - The only way I know is to use a Parameter file. It's not just for text sizes. In 16.2 you can now load colors, grids, artworks, nc drill, shape settings and many more...... well worth the file - import - parameters menu pick. If you set a user preference parampath the location will be under the library button.
    Steve
