  3. Solder Paste for BGAs
  • Subscribers 162
  • Views 14221
Olek
Olek over 17 years ago
Is solder paste required for soldering of BGAs?
BGAs "pins" are solder alloy balls that melt during the soldering, so I wonder if solder paste is needed.
I'm creating footprint for the BGA (1mm pitch, 576 pins) and I wonder if the padstack pad on  solder paste layer should be defined.
In other words, should solder paste stencil have openings for BGA "pins"?
  • redwire
    redwire over 17 years ago
    Yes.  Amount? That depends.  Check with your assembler on what they want.
    Remember that not all BGAs use eutectic balls.
