  3. how to draw a line in Concept HDL?
  • Replies 11
  • Subscribers 167
  • Views 23121
peter zhu
peter zhu over 16 years ago
A basic question, may be silly:
 How to draw a line in Conecept HDL? Not signal, just a line like it in Orcad capture.
There is only a circle tool button on Concept HDL.
 LIne is useful to draw some tables and other notes, we also need we rectangle tool.
Peter
  • ahmetozsoy
    ahmetozsoy over 16 years ago
    Just "draw wire" and do not assign a net/signal  on it. I think that's all.
    Regards
    Ahmet
  • peter zhu
    Hi, Ahmet:
    I don't think so, property and color are not different, also the cross piont will be placeed a dot automatically, deleting such dot will lead to generating connection error.
    Peter
  • ahmetozsoy
    Hi Peter,
    As I understand you want to draw just a line. I attached an image of a wire drawn like a line but when you look at the attribitues you can see this line is a wire without a signal name on it . And if you want you can change its color you can do by picking up a color. And if you want to draw a rectangle you need to draw 4 lines.
    Note : the line you see is   with the blue wire is a patterned - - - .
  • peter zhu
    Hi, Ahmet:
    Thanks for showing this. they are still wire connection and will create dot. I think this is last choice if there is really no line tool. but Circle tool is ok.  Concept HDL is 16.01 now, if there is no line tool, I can not imagine. Such fuction should be ready in 1.0 version  of any other schematic tools. All engineers and our local FAE can not find line tool in DHDL16.01.
     I saw you are using this tool, do you do inter-page connection check that there is no off-page symbol on it? We enounter several deadly connection errors in several projects becuase of numerous shamtic pages. this tool simply connect all together if they are same name. off-page symbol has no connection purpose.
     Peter
  • ahmetozsoy
    Hi Peter,
    Yes you are right. This line still a signal but doesn't create any errors and you may use it like a line as I did. I have been using DEHDL 16.2 the latest one. There is still no line tool :( . I have attached an AVI file for you in the zip file. If you examine this video you can realize that you can use the wire as a line as well as a signal. Only pin connections require the signal name. If you draw  a wire thrugh a pin you must assign a signal name on it otherwise you should not. The dots are just a visual point.
     I wish this helps.
    Actually in the learning HDL I have seen many issues like this. This schematic tool isn't a perfect one but it is flexible and effective .
    I have used Altium Designer Schematic and from the visual point of view it  is perfect.
    Regards
    Ahmet
    capture-1.zip
