  3. Unused Pads suppression
  • Subscribers 163
  • Views 17191
archive over 17 years ago
I have a board that I have suppressed unused pads and vias.  When doing a copper fill area, the fill has places where a drill hole that is part of the same net gets close or just touches the fill.  Is there a way to correct this?  An image of the problem is attached.
Thanks!
vias.doc
  • steve
    steve over 17 years ago
    In constraint manager check your hole to space constraint settings. You may also need to check the analyze - analyze modes to ensure the hole to options are activated.
    Steve
     No matter what I set the shape to hole spacing to, it does the same thing.  All of the settings in analysis modes are turned on.
    Barry
    I found the solution.  I had placed on oversize value for line/cline in the dynamic shape instance parameters.  This was forcing the fill to clear the via that it is supposed to be connected to.
    I don't see a way for DRC to catch this.  I generated gerbers and these were caught visually.  Is there a way to catch them with DRC?
    One more note on this in case anyone ever has this issue.  When the oversize amount forces the fill to be pushed more than half way over the via, the pad for the via is turned off and it looks like the attached drawing.  If you decrease the oversize until the fill is at the halfway point of the via, the pad is turned on and the problem goes away.  Still, it would be nice for DRC to flag these.
  • steve
    Barry - Can I suggest that you raise this issue direct with either Cadence via sourcelink or your local support. I think this is an issue that needs to be fixed.
