  3. .drl file issue
  • Subscribers 163
  • Views 15281
.drl file issue
girish
girish over 17 years ago
Hi, I am facing some unique problem with drill chart ,same drill size coming as two times (pls ref attched figure ).and drill chart & .drl file are mismatching Regards, Girish
  • aruprecht1
    aruprecht1 over 17 years ago
    Look at the Drill Customization table. You either have a different Symbol Size or Tolerance for one of the drills
  • girish
    Thanks arup for your feed back ! This happened becoz two pads having same drill size but the padstck name is different . IN .drl file Oblong pad drill detail & its xy co-ordinate not coming , what we have to do to come in drl file . ? Regards, Girish kumar Bangalore
