  3. Setting up Buses
  • Subscribers 162
  • Views 14978
Setting up Buses
xmoix
xmoix over 17 years ago
Hi!
I'm using Allegro PCB Editor 16.2 and in one design I need to set up a series of nets as buses, because I need to route them together,
as close as I can.
 How can I do this?
Thanks en advance!
  • Rik Lee
    Rik Lee over 17 years ago
    You would add the collection of nets (buses) to a special spacing rule set which would have a different spacing than the default nets. These could also be added to net classes and then your constraint could control net class to net class spacing. It's not a short writeup.
    There is some training on Sourcelink which discusses the Constraint Manager with CSets and the Physical/Spacing rule sets:
    http://sourcelink.cadence.com/docs/files/Training/spb160/pcb_cnsmgr/features/phys_spc.html
    In short:
    Add a spacing rule set
    Setup the constraints > Line to <element> etc.
    Add the net(s) into the spacing rule set
    If you need to control the "bus" to another "bus" or different routes you then need to look into Class >Class assignments.
