  3. Failed to export partial ODB !!!
  • Replies 7
  • Views 19239
Ineedhelp
Ineedhelp over 17 years ago
 Hello!
I'm working with Cadence Allegro 16.01 and want to export ODB++ File. (ODB++ inside Version 8.2.0).
I choose:
- Gzip
- Partial ODB++
>> Begin Translation... >> Translation finished successfully
Then the Export Setting Popup appears.
I choose:
- Assy
Does anyone know which problems are there?
  • Rik Lee
    Rik Lee over 17 years ago
    The solution on Sourcelink alludes to a package boundary height that exceeds what would be 'normal' e.g. 2000 MM.
    If you already have the line:
    attr_value_correct=yes
    and you have closed and then re-invoked the Valor GUI re-run your job and then look at the log file, it will point to the problem component in most cases.
    Job=odbjob, Step=pcb, Layer=comp_+_top, Component=TP41  :  illegal value 78.740158 for attribute .comp_height was changed to default 0.000000
    Additionally, you could create a report using the extract view file below to scan and see if any of the information isn't 'typical'.
    GEOMETRY
      REFDES!=""
      CLASS="PACKAGE GEOMETRY"
      SUBCLASS="PLACE_BOUND_TOP"
      OR
      SUBCLASS="PLACE_BOUND_BOTTOM"
        REFDES
        SUBCLASS
        GEO_PACKAGE_HEIGHT_MIN
        GEO_PACKAGE_HEIGHT_MAX
    END
  • Rik Lee
    GEOMETRY
      REFDES!=""
      OR
        REFDES
        SUBCLASS
    END
