  3. Panelization
  • Subscribers 166
  • Views 15914
Panelization
Carvey
Carvey over 16 years ago
Hello
Using 16.2 software.
Interested in doing our own panelization of our gerber files.
Is anyone doing this with 3rd party software that they would recommend?
 thanks
carvey
  • steve
    steve over 16 years ago
    Carvey
    Have a look at downstream technologies Blueprint Software. This takes an odb++ file from Allegro/Orcad (or gerber if you wish) and is great for general pcb documentation as well as panelisation.
    Steve
  • CubbyBear
    CubbyBear over 16 years ago
    I used CAM 350 for panelization in the past. It's a good, versatile tool. You could also use the Cadence add on Object Cam, but it's a pain.
  • steve
    Do you have more details for Object CAM (just curious......)
  • CubbyBear
    Object CAM must be an add on? Not sure about that, but we use it to panelize where I work now. It's a bit quirky to use, and not real versatile, but it does do the job if all your after is panelization. Personally, I don't think Allegro is all that great a drafting tool, but that's another issue. What you do with Object CAM is create a new file called Panel and open it. Go into Object CAM and the file structure is converted to a Panel- there will be a pop up asking if that's the intent. Once that's done a link must be established to the .brd file(s), and the specific layers and technology must be defined. Once that's all done, the specific board loc coordinates must be provided. The boards can be rotated and mirrored if so desired. The boards then pop in at the coordinates, and your off to running your tooling files. It's important to note that the board files within the panel are not editable. They are simply photoplotable images. Panel data can be added- fiducials, bad board marks, etc. - but the .brd files cannot be edited. I thinl Object Cam would be better if the CAD tool (Allegro) itself was a better drafting tool- but it really lacks in that regard. What I've written above is very general and the real deal typically confuses the hell out of most people until they run it several times. As I said, it's a very quirky tool, and if one thing is wrong, it won't work correctly. The most common issue is missing data if the files aren't set up properly. You've got to spend some time with this one to get the hang of it.
    Hope that helps.
  • Carvey
    Thank you for your reply.
    We are looking at getting a CAM350 software program.
    What we are doing now is creating the panel outline with all the necessary data in AutoCAD and then DXF that file into the board layout.
    Then it becomes part of the Gerber Data sent to the Vendor.
    It works ok but we would like to look at something else as well.
    carvey
