  3. Changing the net name of a via
  • Replies 10
  • Subscribers 167
  • Views 22145
KImJ
KImJ over 16 years ago
 Hello
 Is there a way to to change the net name of a via in PCB Editor 16.2?
 I am having a few via's who is assigned to a 2V5 Net. I would like to assign them to GND.
There doesn't seem to be an easy way to this. Is my only option to route a new via?
Regards
 Kim
  • CubbyBear
    CubbyBear over 16 years ago
    First isolate the via, then just connect into it with the net you want.
  • KImJ
    Thank you for you're response but I can't make it work.
    I have tried to connect to the 2V5 via from a GND via with a cline but I get a DRC (V-L) and the net for the via does not change.
    Any other suggestions
    Regards
    Kim
  • pcbgeorge
    pcbgeorge over 16 years ago
    Message
    1. Isolate the via.  Void any plane under it so it is not connected to any shape, or move the planes so they are outside the board outline.
    2. Connect the via with a cline to an entity assigned to the target net.
    3. Remove the manual void or move the shapes back where they belong.
    George Patrick
    Tektronix, Inc.
    Central Engineering, EDS Applications Support
  • pcbgeorge
    Sorry, folks.  I only sent the last message (and this one) once.
  • KImJ
    Hello again
    Thank you for the reply.
    I have tried the above and I still can't make it work.
    I have isolated the via and it is not connected to any net (Not On A Net). When I try to connect it to a an other net I get the following message:
    W- (SPMHA1-91): Illegal connection.
     Any ideas?
    Regards
    Kim
