  3. Dynamic shape going out of date when editing constraint
  • Views 13092
NormK2
NormK2 over 16 years ago
New to 16.2, in 15.7 when changing a shape spacing constraint it would ask you if you wanted to Disable fill?
When doing the same in 16.2 it automatically disables them. Is there a switch to set to make it ask you?
thanks in advance
  • dschaefer
    dschaefer over 16 years ago
    Not sure if this is what you want ..
    Under "Display - Status" is where you can control shape fill. Set it to Disabled if you only want to manually update shapes ("Update to Smooth").
  • NormK2
    no.....what I"m looking for is what use to happen in 15.7
     If you change a shape constraint, it use to tell you that changing this will need shapes to be updated. Do you want to update shape now or disable fill. This would happen while you were in the constraint manager. What happens to me in 16.2 is they just automatically disable the shapes.
