  3. how to add padstacks to a package design?
  • Subscribers 166
  • Views 15574
blackflowers
blackflowers over 16 years ago
well, i have created a padstack and now i have a new package design. but it's still empty. ¿how can i add my padstack to the package?
regards ;)
  • Rik Lee
    Rik Lee over 16 years ago
     Padstacks (Pins) are added into .dra files through the command 'add pin' (Menu item -- Layout >Pins. You then select the padstack, the pin type (Mechanical or Connect) the copy mode, rotation, pin number, textblock to use for the pin text and the text offsetin the Options tab. Digitize the location in the editor canvas and continue adding pins until you have the required number and locations.
    ~Rik
  • John Davies
    John Davies over 16 years ago
    The Allegro User Guide on Defining and Developing libraries explains how to create a symbol clearly. There is a little more in my tutorial at <http://userweb.elec.gla.ac.uk/j/jdavies/orcad/>.
  • blackflowers
     i have created the padstack, and i have saved it:
    http://img32.imageshack.us/img32/6851/clipboard02myp.jpg
    but i can't find it when i try to add it to my symbol package:
    http://img34.imageshack.us/img34/5109/clipboard01wce.jpg
     how can i find it?
  • Rik Lee
    Ensure the padstack is in a location that your padpath points to.Type set at the Allegro command line to get a listing of your paths. You can change the path in your User Preferences.
    Setup >User Preferences;  Paths >Config
