  3. Aspect ratio of Via
  • Subscribers 166
  • Views 12737
Aspect ratio of Via
girish
girish over 16 years ago
How aspect ratio related plating thickness of via ? Regards, Girish kumar
  • ungas
    ungas over 16 years ago
    Hi Mr. Girish,
     Aspect ration is defined as the ratio between the board thickness to the smallest hole diameter.  The higher the aspect ratio, the more difficult it is to plate the hole walls which also means that it is more difficult to achieve the desired hole wall thickness.
  • girish
    Thanks Ungas for your response .
