  3. PSPICE Simulation Error Message: Devices Failed to Conv...
  • Subscribers 166
  • Views 20041
PSPICE Simulation Error Message: Devices Failed to Converge
GoldenEagle
GoldenEagle over 16 years ago
I am trying to run a simulation on a triac circuit that can switch to either 24VAC or Ground.  The problem that I have is that PSPICE wants MT1 of the triac to be grounded.  If I ground MT1, PSPICE will simulate the circuit.  However, this leads to an incorrect representation of the circuit I am trying to simulate.  Sure, if I wanted to switch to ground, it would be the correct output, however, the simulation would not tell me if the triac is actually being triggered.  Also, if I did that, when I wanted to switch to 24VAC, I would only see a ground level signal which is incorrect.  Any advice would be appreciated.
    This question should really be in the PCB Design forum.
  • Asparky
    Asparky over 16 years ago
    How have you tested and validated he model for the triac?  Most common problem I run into is bad models.  Make the most simple circuits possible to test it for expected behaviors.
  • Sekhar
    Sekhar over 16 years ago
    Hi ,
    For Convergence Problem ,Try this :Simulation Settings->Options and Enable Auto Converge Option.
    Sekhar
  • lucasjardim
    lucasjardim over 12 years ago
     Thanks for the help.
