  3. Need Help with Allegro PCB editor 16.2
  • Replies 8
  • Subscribers 166
  • Views 16041
HGarcia
HGarcia over 16 years ago
Hello Everybody,
I need help for a PCB that I'm routing in Allegro PCB Editor 16.2. I'm routing a BGA breakout using arcs, but these arcs have to be with a specific raidus. I tried to use arcs w/radius and the arc generated appears in etch subclass but not as a Cline, because of that I couldn't connect it to a net. Also, I tried to route using arcs but I couldn't get the specific radius what I need. Is there a way to change lines to clines? or how can I route to get a specific radius?
 Thanks a lot.
  • steve
    steve over 14 years ago
    You can do this in 16.3 but you need to be on the latest hotfix and have an XL License or above, then type set snake_enable at the command line (you can use env to set this automatically).
  • anniesmom1999
    anniesmom1999 over 14 years ago
     Steve
     Once I type in set snake_enable - what am I doing? add connect line? as a line or arc?
     Thanks!
  • anniesmom1999
    http://www.youtube.com/watch?v=ujMN-_Zc2eU
    I found this in the linked video.
    After typing in set snake_enable I typed snake and tweeked the options tab.
     Thanks!
