  3. Error: "...other program is busy..."
  • Views 4202
trieste
trieste over 16 years ago
Running OrCAD 9.1. After creating a schematic and Simulation profile, when I hit the Simulate button, I get the following error window, labeled "Server Busy": "This action cannot be completed because the other program is busy. Choose 'Switch To' to activate the busy program and correct the problem." It provides two buttons that can be pushed: "Switch To" and "Retry".
"Retry" simply repeats the above and gives the same result.
"Switch To" gives the windows START menu, i.e. the list of programs. I can run any other of my programs, but when I go back to OrCAD, I get the same error window. If I run Task Manager, it shows only the OrCAD Capture task running (assuming I closed the program I just ran); no other tasks are listed. If I terminate it (this seems to be the only way of stopping it), when I run it again, or even if I create a new schematic and simulate it, it gives me the same result as above.
Any idea what is going on?
  • oldmouldy
    oldmouldy over 16 years ago
    The programs are not correctly installed, actually not registered correctly in the registry. The RPC server mechanism will require 10 attempts of the "Retry" button to get the simulator to run. Equally, it is unlikely that you are running 9.1 in a supported environment so you may consider getting the latest Demo version of the software.
  • jiyong
    jiyong over 16 years ago
    Dear
     my orcad is 16.2.0. I use the remote license server. why do I also meet this problems?
     thanks
  • RAMA123
    RAMA123 over 14 years ago
     Even i am facing this error.Suddenly Orcad is running slowly and throwing this error.It worked perfectly yesterday.
