  3. Grid Settings
  • Replies 7
  • Views 14725
Grid Settings
Jerry Wilson
Jerry Wilson over 16 years ago
Hi Everyone
I'm going  work on a skill code to read the grid settings of a design.
 I have attached the snap shot. Please advice on how to get the grids value.
Regards
Jerry
  • EvanShultz
    EvanShultz over 15 years ago
     Hi Dave,
    This function works perfectly. Thanks!
    BTW, how does one learn about undocumented functions? Or private Cadence functions beginning with "_", that I've seen you mentioned before. Have I missed the documentation for the undocumented functions? :)
  • eDave
    eDave over 15 years ago
    Hi Evan,
    Generally undocumented commands are risky to use - they may (and often do) disappear between releases. If you do find one that you regard as being necessary you should raise an enhancement request to get it made "public".
    Of course, because they are undocumented, you will have to guess the command syntax. Easy for some commands but not others. However, using the command: arglist usually helps.
    The trick for finding them is to search the symbols used in the lisp symbol list: oblist.
    I'll post some code over in the Skill forum.
    Dave
