  3. Grid Settings
  • Replies 7
  • Views 14722
Grid Settings
Jerry Wilson
Jerry Wilson over 16 years ago
Hi Everyone
I'm going  work on a skill code to read the grid settings of a design.
 I have attached the snap shot. Please advice on how to get the grids value.
Regards
Jerry
  • EvanShultz
    EvanShultz over 15 years ago
     Hi Jerry,
     I'd like to know how to do this too. Did you ever find a way?
    You might want to post this question to the PCB SKILL forum instead of the PCB Design forum, as it's a SKILL question.
  • eDave
    eDave over 15 years ago
    You can try using the undocumented 16.3 command axlDBGridGet. It will give you grid information for etch subclasses.
    e.g. axlDBGridGet("TOP") => (nil name "TOP" objType "grids" readOnly nil xOrigin 0.0 yOrigin 0.0 xMajor 1.0 yMajor 1.0 xGrids (1.0) yGrids (1.0))
    If you still need it, I have some code that will get all the grid form information but it's a real kludge.
    Dave
  • Jerry Wilson
    Jerry Wilson over 15 years ago
    Hi Dave
    Yes please. Can you send the code over.What i have done is instead of checking, i have permenantly set the grids in my code to be 0.001
    axlShell("define grid")
    axlShell("setwindow form.grid")
    axlShell("FORM grid non_etch non_etch_x_grids 0.001")
    axlShell("FORM grid non_etch non_etch_y_grids 0.001")
    axlShell("FORM grid all_etch all_etch_x_grids 0.001")
    axlShell("FORM grid all_etch all_etch_y_grids 0.001")
    axlShell("FORM grid done")
    Thanks\
    Jerry.
  • Jerry Wilson
    Hi Evan
    I was unable to check the grids. What i have done is set the grid permanently to 0.001.
    Regards
    Jerry
  • eDave
    Hi Jerry,
    See attached. I hope you can figure out how to use it without help.
    This is a usage example:
    layers = AFn_getGridSettings()\
    layers["TOP"] ->spacingx
    Dave
    AFn_getGridSettings_public.zip
