  3. Etch spacing
  • Replies 9
  • Subscribers 162
  • Views 17410
Etch spacing
justintesmer
justintesmer over 17 years ago
Ok so, I'm trying to make a quick and dirty board without a netlist because it consist of only cantact pads and solder pads.  However, i have two pads that need to connect, then connect to a via and I cannot get OrCAD to stop displacing the copper on one of the padswhen using route->connect.  I triedunchecking the "replace etch" check box in the options, i tried using lines of top copper rather than a route, i triedusing the "defer dynamic copper" option, but nothing has worked so far.  the bottom of the board has single pads that connect to the vias no problem, but for some reason i canot connect two pads together, both defined as top copped on a dummy net.  any ideas?
thanks,
-justin
  • David G
    David G over 17 years ago
    Justin,
    have you tried setting the bubble option to off when routing
    this should work
     david
  • justintesmer
    Yes, bubble is set to "off" in the options tab.
  • redwire
    redwire over 17 years ago
    Hmmm sounds strange. Can you post up your brd file?
  • justintesmer
     have a go at it
    http://www.4shared.com/file/121523987/4618f183/connection_board_side_a_fanout_v1.html
    thanks,
    -j
  • redwire
    Ok, I see your board but you didn't leave any hint traces on there... I think I know what you're trying to do. On the top copper, go ahead and change the shape type to static (Shape->Change Shape type) and it will work with a DRC.
    Allegro actually thinks of the dynamics as two different nets even though they are both "dummy"
    Does that work for you?
