  3. Analog and Digital Ground connection
  • Subscribers 168
  • Views 16025
David G
David G over 16 years ago
 does anyone know how to represent in capture CIS, when you need a digital and an analog GND to connect
on only one point, if I tie both grounds using a wire then orcad makes a short and I lose one of the nets
what I have been doing so far is to just draw a line between both GNDs and on Allegro use the short_net properti
but was wondering if there is a better, or correct = ) way to do this?
 thank you
  • Khurana
    Khurana over 16 years ago
     I don't think this is possible in the schematic tool since "one point" will mean "all points" if two nets are shorted i.e. one net (name) always takes over when the nets are shorted or if two nets with different net names are joined, then check yields an error and therefore netlist cannot be generated.
  • elcokev
    elcokev over 16 years ago
    what I do is have a symbol with 2 connections and a foot print with 2 small touching pads this then allows 2 signals to joint at one point.
    hope this helps.
    best regards
     elcokev
  • Tanveer
    Tanveer over 16 years ago
    Connect them with zero Ohm resistor.
    Regards
    Tanveer
  • bono
    bono over 15 years ago
           I have met the problem also, and find the answer on this page.   That's the zero resisitor and "touched" pad.                                       I am  glad to introduce another method,  called "touched" shape.       Say two shapes for digital and analog ground, created as dynamic positive shape , after you finish most layout jobs, first change these two shapes to static shapes , then at the intended connection point,  put the third static shape touched the two adjacent ground shape, assign the shape net as one of them.  Now get two touched shapes.   though DRC error exists,  for the film result in fact the two ground shapes are connected.
        Regards
        Bono
  • ArturoArias
    ArturoArias over 15 years ago
    I use a ferrite bead... 120 Ohm or higher, and depending on the space I have, I choose the footprint. Remember this: the bigger the footprint, the higher the impedance and the capacity of driving current. Regards. Arturo
