  3. Problem Updating Component in PCB Editor
  • Subscribers 162
  • Views 18285
ace5582
ace5582 over 17 years ago
 I'm using Orcad PCB Editor v16.2. I started a PCB design, imported a netlist from Capture CIS, and placed all of my components. I then changed one of the components (modified it's DFA and Place boundaries). I assumed it would be easy to update my design with this change...
 1) I deleted the old component and placed it as a "components by refdes" component again. The component didn't update.
 2 )I then went to the Advanced Settings tab in the Placement window, enabled the "Library" option under the "List construction" setting. I tried to place the component under the "Package Symbol" dropdown menu. Still no change...
 3) In the main menu bar I went to Place > Update Symbols. I clicked on "Package Symbols". I then clicked on the component I wanted to update. I enabled the "Update symbol padstacks",  "Reset symbol text locations", "ignore FIXED property" options and clicked on "refresh". The log showed the component updated.
 4) Looking back at the design the component didn't update. I tried steps 1 & 2 and still no update.
 5) I can create a new board design and place the component. and it is an updated version.
 6) One other thought: the refdes text block size for that component doesn't match the one it's supposed to have either...
Any thoughts on what I'm doing wrong or why it's not working?
Thanks in advance!
  • Rik Lee
    Rik Lee over 17 years ago
     Have you tried dbdoctor  (Tools >Database Check) on the design and then execute Update Symbols?
  • ace5582
     I just tried your suggestion and no fix.
  • redwire
    redwire over 17 years ago
     Hi ace--the procedure is simple.  Deleting and replacing doesn't fix it as you found out.
    Only during place-update symbols does it work. But, where does it get its symbols?  First occurrence found in your psm path.
    Sounds like you have rogue copies floating around in other directories.
    Do a symbol library path report and see where it's getting the current symbol from.
  • ace5582
     Thanks redwire, your suggestion fixed the problem. For some reason Orcad was using the symbol from the same directory the PCB design is in, but that directory is not in the psm path. I deleted that symbol and re-ran symbol update and problem solved.
    Thanks again.
  • redwire
     I wonder if "." is hiding in the PSMPATH from you as it's typically part of the default install.
    One way you can see your real path is type in "set" at the Allegro command line.
    Scroll down and look for psmpath and see if "." is in the definition.  If you don't want it there (most installs have it) then you need to modify with  Setup->User Preferences and be sure to look at the expanded view
