  3. Documentation for allegro scripts
  • Views 18977
arcwilson
arcwilson over 16 years ago
Anybody know of a good place to get more documentation on allegro scripting? (i.e. filename.scr not skill)  I'm wondering if there is a users guide or something similar.  The only information I've found is from the help menu (I searched "script") and it does not give a good overview of writing scripts.  For example, I know that I can execute commands from a script if I know the command's name to start with, but I don't know where to look when I need to figure out how to script things whose names I don't know.  For example, I have no idea what the command equivalents are to many of the preferences.  Is there a way to find those out so I can script changes to them?
What I've been doing so far is just using the script recorder in pcb editor, making the changes I want, and then reviewing the .scr file to see what the editor did.  This is kind of painful, as the script recorder only records changes, and therefore to find out how to change all the items in a menu, I have to go through and change every item by hand.  I wish I could just hover over a button in pcb editor and have it show the name of the corresponding scripting command.  Anybody know of something that might be like this?
Chris
  • arcwilson
     For example, if I wanted to find out how to script turning grids on and off, where would I look?  By scripting it within the editor, and looking at the results, it appears that I need to run:
     prmed
     setwindow form.prmedit
     FORM prmedit view_grids_button
    It seems like there might be a command for turning the grids off via a single command, but I have no clue where to look to find out.
  • lcanx2
    lcanx2 over 16 years ago
    You might try Tools->Utilities->Keyboard Commands from the pulldown menu.
    This was posted recently by another member and is an excellent source for not only a list of the keyboard commands themselves but also invokes them.  You will find the command for turning grids on and off there.  You can also specify if you would like Help on the command rather than having the command executed.
    As for capturing commands that change options within applications, you can try using the commands that are output to your  journal file (allegro.jrl). This will avoid having to turn scripting on.
    Bill
  • rpieper
    rpieper over 16 years ago
    My guess is that 95% of people record what they want to automate and then open .scr to see the commands.
