  3. COMP_DEVICE_TYPE
  • Views 14779
COMP_DEVICE_TYPE
JPeter
JPeter over 16 years ago
Hi.
I am using v15.7, and working on generating a report to use as a pick and place file.
I got most of the fields I need to see.  All of them, actually, but when I include comp_device type, it is including too much info.
RESISTOR_DEFAULT-7023-8252,82.A
For this item, it's OK.  The part number (7023-8252) is complete.  Why an I getting what looks like a value included at the end? (82.A)  What is this?
For other instances, if the string gets too long, it is truncating my part number:
CAPACITOR_DEFAULT-CDR31BP151BJA
The part number should be CDR31BP151BJUS, but it has truncated the "US" and added "A"
My assembly people are getting confused.
The part number property is included with each of my symbols as :"USERPART#" on "ASSEMBLY_TOP"
 How can I get it to output only the part number without all that other stuff?
John H.
  • rpieper
    rpieper over 16 years ago
    John,
     The information for the Device type is passed through to Allegro from the schematic. So when I click on (show element) my resistor (in my Allegro design) it says Device Type: PASSIVE_RES-127,1%,1/16W, 002_0B. Which can be confusing becuase ithis whole string will be thrown in your comma-delimited extracta output (I'm assuming your using extracta, right?). It's hard to know where the COMP_DEVICE_TYPE field stops. So in my pick-place data it says:
    REFDES,COMP_DEVICE_TYPE,COMP_VALUE,COMP_TOL,SYM_NAME,SYM_X,SYM_Y,SYM_ROTATE,SYM_MIRROR
    R1,PASSIVE_RES-127,1%,1/16W,002_0B,,,002_0402-SMALL_SM,1735.00,795.00,180.000,NO
    So then,  PASSIVE_RES-127,1%,1/16W,002_0B is all part of the COMP_DEVICE_TYPE field.
    If the assembly people are getting irritated (that's good actually --at least they're communicating, which is quite rare) you can just write a PERL script to split this field on commas and then just take the first field. Your second issue seems like a 31 character limit. I haven't verified this but you can try going into Allegro and then your Design Parameter Editor and then Design tab, then change Long Name Size to 100 (default is 31). Let me know!!!
    Robert
  • JPeter
    Thanks, Robert.
    I am playing with a small txt file that I read in when I run Tools>Reports
    It will spit out "PART_NUMBER" if I include it in that .txt file
    First pass, my assembly guy liked it.  :)
    I am working on getting the "USAGE" property of the schematic to output to identify unplaced parts.
    Thanks for the help.
