  3. Irregular Footprints in Layout Plus and/or Help Migrating...
  • Views 2189
Irregular Footprints in Layout Plus and/or Help Migrating Design to Allegro PCB Editor
cwparker
cwparker over 16 years ago
Greetings all- I'm trying to use the following RF connector, Radiall R222508000, in a design I'm working on: radiall.applixia.net/.../resource It has irregular pad shapes in the footprint. I've designed the board in Layout Plus with a different connector in place of this one. I know how to change the footprints, however, I don't know how to create a footprint with pad shapes like this. I've tried attaching an appropriately shaped copper area to a small pin, but when copper is poured around the part it completely floods the copper area. As an alternative, I'd be okay with migrating my design from Layout Plus to Allegro PCB Editor. In attempting to do this (File>Import>OrCAD Layout), the translation aborts with an error "the output directory is not writable". I can't seem to figure out what allegro is trying to use as an output directory... and consequently can't change it. There aren't many directories on this machine that I can't write to... The directory containing the layout file I want to translate IS writable. Any help would be much appreciated!
  • hpattie
    hpattie over 16 years ago
    The write error sounds like a Vista operating system problem. If this is the case Open Allegro using "Run as administrator".
    For the symbol issue, Create a shape symbol in th shape of the connector pin. You can then create a padstack with this shape for the pad. Then create your footprint and use this padstack for the pins.
    Harold Pattie
    harold.pattie@ericsson.com
  • cwparker
    I wish it were as easy as blaming it on Vista. I'm running XP SP3. I still tried running Allegro using administrative privledges, to no avail.
    Creating the symbol in and using the shape as a padstack is something I think I can figure out. But is there a way to do something similar with Layout Plus?
    --Chad
  • redwire
    redwire over 16 years ago
    Run the import again and when finished do "File->Viewlog" -- what does it say?
  • cwparker
    It's not actually generating a log file!
    "<log file name and path> does not exist"
