  3. length matching across groups of nets
  • Views 14217
padmaster
padmaster over 16 years ago
I'm trying to length match a group of nets to the sum of two other groups of nets. Can't seem to figure it out.
Group A - target = 1203.91
Group B - target = 3191.11
Group C - target = 1818.20
Group C must match A + B
I added a delta of 2576.82 to group C, and cleared the "target" field but the target keeps coming back when that group is analyzed.
Any help is appreciated.
  • Dennis Nagle
    Dennis Nagle over 16 years ago
    For your last statement where you clear the target and it keeps coming back: If you have a Delta value that is any value other than null, a target is required. The target can be defined by you or generated by the system but it is required for a Relative Prop Delay case. When the delta value is null, it's a Match Delay case.
    If you are in 16.0 or later and XL or higher, you can make use of the Avanced Constraints feature to either use a formula on the MG constraint value or use a formula to constrain the length of the target you set for Group C based on A + B. There is a tutorial on this feature in your hierarchy: << install_dir >>\doc\cmadvcnstut
    If you don't want to/can't use Advanced Constraints, route and fix the targets for A & B and then constraint the length of the target for C with whatever the sum of their lengths are (use min/max prop delay with a built in tolerance for the min/max values).
    -Dennis
  • padmaster
    I'm running 16.2 with the performancre option only.
    You say constrain the length of the target for group C with min/max values. I see how this works but it looks like I need to remove all group C nets from rel prop delay and enter the min/max values for them. I guess this could also be done with a total etch length group.
    So the sum of A + B = 4395.02
    I have all group C nets with a min/max of 4390/4400.
    Sounds good, thanks for your help.
  • Dennis Nagle
    It would be a matter of prefernce I guess: either put the same min/max rule on all of group C or just make sure the target of group C is the right length and then match all of group C to that target.
     -Dennis
