  3. Auto-Router Unconnects
  • Views 13111
PherricOxide
PherricOxide over 16 years ago
I'm attempting to auto-route a fairly large board file in Allegro PCB design/Specctra. Some parts are already routed, but there are at least 3 layers with no etch at all that the auto-router can use, as well as many other layers with only some etch on them. However, when I run the auto-router, I get a large number of "Unconnections", which never seem to route even after hundreds of route and clean passes. I don't understand why this would happen, because if the auto-router will allow clearence conflicts and crosses at the beginning of routing, what would cause some wires to be unconnects throughout the entire process? I can look at the wires and find that most of them are easily routable by hand without moving anything, so why does Specctra find them so difficult?
  • hpattie
    hpattie over 16 years ago
    Without knowing the specifics of your design, this is difficult to answer. some possible answers are;
    net constraints or properties the will not allow routing.
    inability to fanout or via to  another layer.
    net conflict at the component pin.
    Harold Pattie
    harold.pattie@ericsson.com
