  3. Shematic DRC issues.
  • Views 14718
romesh
romesh over 16 years ago
 I need experts advice to clear some DRC and answer few questions. I have a simple heirarchy block and I get the following DRC error.
Port has a type which is inconsistent with other ports on the net.
I checked couple of times and everything just make sense and I couldn't see any issues.
I also silenced the DRC check for bidirection port and input, output pins to get rid of some of my warning. Just curious to know why there is a DRC for checking bidirection port with input and output pins. I really don't understand the purpose of checking it.I checked my connection and the input from the sensor connects to the micro bidirection pin. I was sure that was right so I muted the error checking for biderctional ports. Will this be ok .
 Thanks in advance.
