  3. edge connecting pad allegro
  • Views 16396
dumarjo
dumarjo over 16 years ago
Hi all,
I need to do a new PCB with edge pin connector. I would like to know how to do this (or document that help me doing it)
I need to do somthing like this.
i'm using allegro 16.2. I have no idea hot to create that padstack.
Jonathan
  • girish
    girish over 16 years ago
     Hi ,
    Attached document may help you . you need to define the pad in shape class & put the origin of the shape where you want the drill  .
    For this type of small form factor better to take guidline from your fabricator before starting .
    Girish kumar
    design rules castellation.pdf
  • dumarjo
     hi,
    i'm not totally sure of what you tring to do with the shape thing.
    From what I understand, I should create a standard padstack but I place the outline of my board accross the hole ? Since we want that hole plated, I don't see any other solution.
     regards
    Jonathan
  • mjmessinger
    mjmessinger over 16 years ago
    That's exactly what you will be doing.  The edge of the board will bisect the holes.  The board gets plated up and then when it is routed out you will be left with half of a plated hole along the edge of the board.
  • dumarjo
     that's make sense !
     thanx
    Jonathan
  • dumarjo
    I made my module and I hope this will work. I just send it to the fab house.
     I would like to know if it is possible to make a symbole dra file with my new board. I would like to import my board in a dra file an changing the side hole to pad. Like this I will be certain that my fottprint is correct.
    JOnathan
