  3. How to rotate a complete pcb
  • Subscribers 166
  • Views 16643
currentsource
currentsource over 16 years ago
dear all,
because i have found nothing about my search in the community i'll ask now:
How to rotate a complete pcb ?
I use a mechanical drawing (imported dxf) in Orcad pcb-designer in some additional layers as like an overlay. Than I have create a pcb as usual.
Now it will be fine to rotate 180 DEG and move the complete finished pcb in my design.
I have try spin, but these does not work, it leaves parts and some other elements on the old place.
Is there a method by filtering only "pcb-elements" and rotate them all?
Thanks all!
  • C Shiva
    C Shiva over 16 years ago
     Select "Move" command, then set "user pick" in Options window, select the elements which you want to move, rotate it and place wherever you wanted.
    HTH
    Shiva.
  • anicca
    anicca over 15 years ago
    Hi Currentsource,
     It has been long since your post, but have you found the answer to your question ?
    anicca
  • currentsource
    currentsource over 15 years ago
    Yes, Anicca, the tip to use move (with proper choosed FindFilter) does work nice.
    Peter
  • anicca
    Thanks, Peter and Shiva !  I must have missed some step when I tried the other day.  It works great now.
