  3. Constraint_Switching
  • Replies 9
  • Subscribers 167
  • Views 16436
girish
girish over 16 years ago
Hi.
I am using Allegro PCB designL(16.01) ver.
I need two switch b/t two (constraint spacing & trace width ) while routing.I know that this tool doesn't support constraint region
 If I set the constraint for higher value, sliding of trace is very difficult .
pls suggest is there any alternate method to switch b/t two constraint, (attached image for more clarity)
Girish Kumar
  • hpattie
    hpattie over 16 years ago
    Constraint Areas are found on the Board Geometries Tab, at the bottom.
    Harold Pattie
    harold.pattie@ericsson.com
  • hpattie
    Harold Pattie
