  3. Library PCB Editor, help me
  • Subscribers 166
  • Views 14231
danith72
danith72 over 16 years ago
Hi everybody!! First, thank you for read this.
How can I creating and editing libraries in OrCAD PCB Editor?? I've created new footprints for my pcb. I've putting in OrCAD Capture. I've created the netlist very well. When i'm going to place the component, I place - Manually and "Component by refdes" and i appear all components my PCB, but if i check any component OrCAD say me:
 E-Symbol no found for component...
 I've created footprints and i've added it to OrCAD Capture, why i can't place components???
 Thank you very much!!
Best regards
  • Nagaraj Shanmu
    Nagaraj Shanmu over 16 years ago
    You have created the footprint but you need to make it available in the library path.
    use the menu setup-->user preferences-->paths-->library, here you set your padpath - for the padstack to get listed and psmpath - for the symbol to get listed.
    good luck!!
    ~Nagaraj.
  • danith72
    Thank you for your reply Nagaraj Shanmu!!
    I did it! But I have the same problem. How i create the footprint with OrCAD PCB Editor? I made the new footprint in Library Manager in OrCAD Layout and then my library is .LLB. I need .psm y .dra. How can i get it?
    Best regards,
    Daniel
  • Nagaraj Shanmu
    Hi Daniel,
    Since you are new to Orcad PCB editor, I would suggest you to go through the below tutorial on Library development,
    The tutorial is available in your installment path\doc\algrolibdev for example my installation path is C:\Cadence\SPB_16.2\doc\algrolibdev.
    I have attached the document here.
    Good luck!!
    ~Nagaraj.
    algrolibdev.zip
  • danith72
    Hi Nagaraj Shanmu!
    Thank you very much for your help, I'm going to read the tutorial. I believe that it's the best.
    Thank you very much for your time and your help.Best regards,
    Daniel
  • laszloee
    laszloee over 16 years ago
     When you're all gonna have a chance, check out a real design package. IE: PROTEL.
    Then you're going to realize how much time you're wasting from your life and since time is money..so figure the rest of it !
    Best luck for all of you to trying reinventing the wheel !
