  3. Anyone doing .4mm pitch BGAs yet?
  • Views 12582
Cadpro2K
Cadpro2K over 16 years ago
Doing a bumped bare die part, .4mm staggered pitch. Is anyone else doing these? Can they be done without stacking the vias to breakout the pattern? I don't see a way but to stack the L1-L2 microvias (via in pad) on top of the buried vias.
Using .010" pads, .004" vias in the pad (L1-L2) and .004" traces to break it out.
Any other ideas?
Thanks.
  • CubbyBear
    CubbyBear over 16 years ago
    We're using .4mm BGA's with stacked HDI microvias using a 4-2-4 stackup. Depending on your board density, it's going to be tough to impossible to break them out otherwise- IMO. The vias are .226x100mm, line's out of the BGA .063mm MIN, .075mm typ. We can stack 4 deep to the Core on either side. We have special HDI vias to specific core layers to pick up PWR, or a drilled thru hole core via to get thru to the other side. Fun stuff.
