  3. No Board outline when artwork is made
  • Replies 15
  • Subscribers 166
  • Views 24249
Dennis H
Dennis H over 16 years ago
I have a PDF called A basic intrduction to Cadence Orcad (Allegro) 16.2 PCB Designer.
I have been following that to help me learn  this program, so far it has worked but when I make the artwork (gerber files) Fig.25 says the Board Outline is not included in the films. Why is that? the PDF doesn't give me a reason why.
 Doesn't the PCB Manufacture need the outline to make the board?
The PCB software I use now is Orcad Layout 9.0 and I can make outlines for the Artwork (gerber files).
Any help is appreaciated...
Thanks, Dennis
  • steve
    steve over 16 years ago
    It's related to your board outline being zero (0) in width or thickness. Under the aerwork settings there is a undefined line width. Specify a value here (I suggest 10 mils or 0.254mm). Remember to do this for each artwork. You will then see a thickness in your gerber data. Some people generate an artwork that just contains the board outline.
  • Dennis H
    Hi Steve,
    Thanks for the info, I'll give it a try and let you know...
    Thanks, Dennis
  • redwire
    redwire over 16 years ago
     Actually it's not needed.  It's comfort food for them.  There have been 1 or 2 specfic vendors I've used in the last 100 or so boards that asked for it as a cross-check.  Outputting it on its own film is best.  Just create a film, set up just the outline to display, match the film to the display and then set the line width for plotting for this layer.  Voila!
  • Dennis H
     Hi Steve,
    I tried putting 10 mils in the undefined line width box for each artwork and I left everything else the way it was and it still didn't work.
    Thanks, Dennis
  • steve
    Dennis. Can you please confirm that the board geometry / oultine class/subclass is included  in the artwork film you are viiewing ?
