  3. how to place the board in the sheet when printing?
  • Views 12966
blackflowers
blackflowers over 16 years ago
 hi, again, ¿how can i place the board in a sheet when i print the board? in orcad when you print the design you could specify x, and y, coordenades for positioning the board on the sheet when printing. can be done something similar with pcb editor??
thanks!
  • Cadpro2K
    Cadpro2K over 16 years ago
    The board will be printed according to it's graphic position (e.g. how you're displaying the board in your monitor). If it doesn't print correctly, you can move the board around on your screen, and get a different result.
    BTW, I always use PDF output when I print so I can modify the paper display before I print the actual paper.
    Good day.
