  3. Problem Installing Orcad 16.2
  • Views 14825
philip85
philip85 over 16 years ago
 Hi, I am having difficulty when installing Orcad 16.2 on my Vista 64-bit machine. It is the demo version of Orcad. I do not understand what the readme means by saying you must 'extract the archive using the path\folder option'. I just proceeded and unzipped the file as I normally would. the install then seems to work fine until the very end when after I have said 'yes' to associating the various file associations with Orcad, then all the various programs, Captue CIS, Layout, PSpice open up saying they have encountered a problem and are not working. What could I be doing wrong?
  • AmitNangia
    AmitNangia over 15 years ago
    hey by  path/folder it means dat wen u rght click a rar file to extract it then it shows an option taht says extract to [name]\   folder   ..............for instance it is a abc.rar file den rght click it to select extract to abc\
    i jst guess dat might help u 2 install orcad
  • eephillip
    eephillip over 15 years ago
     When you download the program they break it into four zip files. You need to extract each zip folder into the same location e.g. C:\CadenceInstall
    When you un-zip the file you should make sure that the file stucture in which is was zipped remains instact. You should end up with the a folder that constains the following.
    setup.ini,autorun.inf,setup.exe, LibCD, Disk1,Disk2,Disk3, Autoplay
    That's it
  • AmitNangia
    i have installed orcad 16.2 demo version...every thing workrd out perfectly,  orcad is working but while i was using orcad capture it doesnt show up any vendors ( or family)  when it is basically needed as u creates a new project...so plz can u help.
    i really dnt have in depth knowledge of orcad , im jst a beginner.......
