  3. Import Image to Allegro
  • Replies 24
  • Views 28806
David G
David G over 16 years ago
Does anyone know if it is possible to import an image into allegro PCB editor,
would like to use image on silkscreen
dg
thanks
  • eDave
    eDave over 16 years ago
    Hi David,
    See my LogoMaker Skill code on the Skill forum  /forums/p/13122/20158.aspx#20158
    Ensure that you go to the final osting for the latest code and read the start of the Skill file for the extra download and installation requirements.
    Cheers, Dave
    This email, including any attachments, is only for the intended addressee. It is subject to copyright, confidential and may be the subject of legal or other privilege, none of which is waived or lost by reason of this transmission. If the receiver is not the intended addressee, please accept our apologies, notify us by return, delete all copies and perform no other act on the email. Unfortunately, we cannot warrant that the email has not been altered or corrupted during transmission.
  • Rik Lee
    Rik Lee over 16 years ago
    There is a raster program in Sourcelink solution 11022718. This will translate the image into a .plt file which then can be read in using File >Import >IPF.
    In addition to the above, there are 3rd party programs available to read raster images (BMP, JPEG, etc) and convert to DXF format that can be imported into Allegro with File > Import > DXF.
    Some links to these 3rd party programs are:
    http://www.imsrv.com/rasterfratz
    http://homepage.ntlworld.com/softsoft/wintopo/index.htm
    ~Rik
  • MAAC
    MAAC over 16 years ago
    Hi Dave,
    I downloaded all the plugin software & gave the path in env..
    After typing logomaker in command window i am getting plugin options..kindly let me know the next steps to follow.
    Thnx
  • eDave
    Did you re-start Allegro?
    Cheers, Dave
  • David G
    yes it did not work
